Post by thunderbolt on Oct 11, 2018 0:40:46 GMT -5
Are the cone type air filters give factory 49cc any to " boost" performance ?
Post by FrankenMech on Oct 11, 2018 7:53:57 GMT -5
Yes, but they have their own set of problems, and you must re-jet and tune the carb to use one. There are trade-offs with many mods.
Post by thunderbolt on Oct 11, 2018 13:02:08 GMT -5
Guess I'll stick with what I have for a while . May do everything at once after I ride a while . Been raining for 2 days no sign of letting up here in Southwest VA .
ratdog
Post by ratdog on Oct 11, 2018 14:16:23 GMT -5
You just mentioned the worst part about one filters. They don’t like rain or puddles.
Post by FrankenMech on Oct 11, 2018 15:46:15 GMT -5
It is never good to do more than one mod at a time, otherwise you have no idea which one (or more) might be causing a problem. Some mods are 'connected' so you have to do several though. -Trade-offs...
Post by diynuke on Oct 11, 2018 16:12:27 GMT -5
Are the cone type air filters give factory 49cc any to " boost" performance ? i have one installed now and well they do give a bit more power but its not really a big difference i kind of like to mod the old air box a bit so it allows a bit more air to pass through. rain? didn't have any problems yet altho I have the foam type air filter and I sprayed it with air filter oil and its hidden in the scoot so its working great for now. 1 thing. it makes sound.. A shit load of sound. xD its louder than my exhaust and its over 108db
Post by thunderbolt on Oct 11, 2018 16:37:06 GMT -5
I'm having difficulty registering it right now . Tx power sports says they've mailed my paperwork but I've not received it. Try again Friday .
Post by scooterpimp on Oct 12, 2018 18:53:07 GMT -5
Always had luck with stock airbox , stock or modded engines.
Post by FrankenMech on Oct 13, 2018 4:29:33 GMT -5
I bought a performance carb and a pod-type air filter and they worked well together, without re-jetting, -but I did do a a a 'few' other mods to the carb...
ratdog
Post by ratdog on Oct 13, 2018 14:41:42 GMT -5
This may sound stupid, but you can get about as much power boost as you are going to get by taking the stock air box apart and removing the “snorkel”. The long straight tube that hooks to the carb and goes inside the air box. Use just that to “test” if you get a measurable power increese. Problem is, you almost certanly will have to reject the carb because it will run noticeably leaner. I would pull the plug and let us see a closeup of the tip. You may be running too lean already.
