Post by Critter from the Rock on Oct 12, 2018 15:16:58 GMT -5
When I hit the starter it just spins or even the kick start what is the issues now?
Post by 90GTVert on Oct 12, 2018 18:17:05 GMT -5
Important question is; is the engine spinning or are you hearing the starter and kick starter working and not the engine spinning?
Post by Critter from the Rock on Oct 12, 2018 18:24:29 GMT -5
Important question is; is the engine spinning or are you hearing the starter and kick starter working and not the engine spinning? Yes engine is spinning
Post by Critter from the Rock on Oct 12, 2018 18:26:13 GMT -5
Engine is spinning Important question is; is the engine spinning or are you hearing the starter and kick starter working and not the engine spinning? It appears that the shaft spinning but not turning over the motor
Post by 90GTVert on Oct 12, 2018 18:31:16 GMT -5
What shaft is spinning? Crankshaft? Kickstart? Electric starter?
Post by Critter from the Rock on Oct 12, 2018 18:32:17 GMT -5
Crankshaft What shaft is spinning? Crankshaft? Kickstart? Electric starter?
Post by Critter from the Rock on Oct 12, 2018 18:33:02 GMT -5
What shaft is spinning? Crankshaft? Kickstart? Electric starter? Crankshaft
Post by 90GTVert on Oct 12, 2018 18:34:28 GMT -5
