Post by stancejontland on Nov 13, 2018 1:04:11 GMT -5
whats up guys. been meaning to post about this but keep getting side tracked with other vehicle problems. but i have been taking my scoot around the block and the sound has been there for a while but seems to go away. but i figured this winter ill do a cvt overhaul. but when im taking off from a stop or low low speed my cvt screeches till about 3 maybe 5 mph. what could that be?
Post by gsx600racer on Nov 13, 2018 1:50:21 GMT -5
Assuming that your engine is a 1E40QMB, I am going to guess that it might be the bearing that supports the rear input shaft in the cvt cover.
Post by stancejontland on Nov 13, 2018 17:24:58 GMT -5
the bearing that sits on that little pin? or i mean it sits in the little recces in the back
Post by gsx600racer on Nov 13, 2018 18:00:59 GMT -5
the bearing that sits on that little pin? or i mean it sits in the little recces in the back Its the bearing that lives here(circled in red)
Post by stancejontland on Nov 13, 2018 18:31:15 GMT -5
yes thats the one i was thinking. can they be replaced? or lubricated?
Post by gsx600racer on Nov 13, 2018 18:42:51 GMT -5
yes thats the one i was thinking. can they be replaced? or lubricated? They are normally sealed. You would have to replace it.
Post by snaker on Nov 13, 2018 18:44:45 GMT -5
It could be one of the driven pulley bearings. They only spin at below clutch engagement speeds like the rpm's mentioned.
Post by stancejontland on Nov 13, 2018 18:59:49 GMT -5
is it just rear input shaft bearing?
Post by stancejontland on Dec 4, 2018 5:37:23 GMT -5
any links to replacement??
Post by 90GTVert on Dec 4, 2018 7:20:38 GMT -5
You can spin the bearings or use your finger to rotate them and feel if they're gritty and listen for noise. Check the cover bearing and both bearings in the rear pulley. If you need to replace the bearings in the rear pulley : www.youtube.com/watch?v=2f-7Q_0GRAICover bearing can be removed with a blind hole bearing puller. The easiest way to deal with it though, is to drill a hole that aligns with the center of the bearing (hint : drill through from the inside while the old junk bearing is in there for proper alignment). Then you can drill a little larger to make it easy to catch an edge or just work at an angle like you're driving out wheel bearings. Use a punch and drive the bearing out. Heat the cover, cool the bearing, and drive the bearing in if needed. Just be careful to only drive the bearing in from the outer edges or using a bearing and seal driver. Don't drive it in by putting force on the center.
Post by stancejontland on Dec 5, 2018 6:16:11 GMT -5
most times when i take my cvt cover off the bearing stays of the pin or shaft so i always have to pop it back in. but couldn't find one online to replace.
Post by 90GTVert on Dec 5, 2018 11:16:28 GMT -5
Post by stancejontland on Dec 8, 2018 8:24:18 GMT -5
ok i defintly will keep that link in mind when i start getting a parts list together
