Post by jdl357 on Nov 20, 2018 21:35:51 GMT -5
Do you guys know what size the big socket is I need to take clutch apart? I tried to use the socket that works on my 2 stroke 1e40qmb minarelli and it was too small. Thanks.
Post by gsx600racer on Nov 20, 2018 21:46:22 GMT -5
1E40QMB Thin nut: 38mm wrench/socket size Thick nut: 41mm wrench/socket size 139QMB Iv seen 34mm & 39mm wrench/socket size You will have to measure across the flats.
Post by oldgeek on Nov 20, 2018 22:04:41 GMT -5
A large adjustable wrench works GREAT in a pinch.
Post by jdl357 on Nov 20, 2018 22:58:51 GMT -5
Great, thanks for the info. That really helps!
Post by tocoo on Nov 21, 2018 6:50:10 GMT -5
for my 50cc 139qmb, it was a 39mm nut, but I replaced it with a 38mm which is the norm?
Post by 90GTVert on Nov 21, 2018 7:41:27 GMT -5
39mm is most common. You can measure the nut to find out for sure.
As long as the thread pitch and diameter are the same and the thickness of the nut causes no interference, it doesn't really matter if it's 38 or 39mm.
Post by FrankenMech on Nov 27, 2018 2:15:09 GMT -5
A cheap pair of calipers will help identify many scoot parts.
Example: Harbor Freight item# 61585
You can get similar units at most tool stores. -Prices and quality vary...
Post by scooterpimp on Dec 2, 2018 7:59:10 GMT -5
1 -1/2" 6 point socket works for me....(=38/39 mm)
