neogie
Post by neogie on Nov 23, 2018 2:59:39 GMT -5
Hi. Just needing advice what type of lube/grease to put on a starter motor reduction gear on a 1e40qmb type 50cc scooter? Or do you not put any lube on it? I need it replaced as it is causing some shaking noise when on idle. Thanks
Post by 90GTVert on Nov 23, 2018 7:24:54 GMT -5
I just put a little all purpose/wheel bearing grease on the shaft that it rides on and inside. Small amounts.
Post by flash2002 on Nov 23, 2018 12:08:26 GMT -5
The other day I bought some high pressure high temperature grease for that purpose. This grease is sticky and won't fly off the parts and is heat proof and cheap.
neogie
Post by neogie on Nov 28, 2018 18:27:21 GMT -5
Hi man. Does this new starter gear need to be heated up when putting back on the shaft? Feels tight than the old one. Exact same specs like the size and number of teeth.
Post by oldgeek on Nov 28, 2018 20:45:18 GMT -5
Hi man. Does this new starter gear need to be heated up when putting back on the shaft? Feels tight than the old one. Exact same specs like the size and number of teeth. Can you post a picture of the part in question?
neogie
Post by neogie on Nov 29, 2018 2:12:54 GMT -5
neogie
Post by neogie on Nov 29, 2018 2:13:31 GMT -5
Post by geoffh on Nov 29, 2018 15:17:18 GMT -5
Neogie,it might be an optical illusion but if the gear on the left is the new one it,s bust it,s out of shape and you will need to replace it.
Just try the old one,I can't see much wrong with it,the bearing should just slip on the shaft the plate that bolts on after holds it in place.
neogie
Post by neogie on Nov 30, 2018 2:59:37 GMT -5
I was just hoping to get rid of that shaking or pinging noise coming from it. But m just hoing to use the old one then.
