Post by milly on Nov 23, 2018 18:25:14 GMT -5
Been running my lml scooter in my spark plug is very clean. As in to rich. Will this cause any problems short term till run in as its damn cold to be working on scooter after all day outside working. Just wondering if it could weaken the oil mix washing around the crank and piston. It's auto lube by the way.
Post by oakleyscoot on Nov 23, 2018 18:53:52 GMT -5
I do not believe a little rich ( fuel side ) would be a problem however being as you have autolube you might wish to check that the oil pump is set correctly.
Typically there is mark (line) on the engine casing pretty much right at where the oil pump is and there is a disk (so to speak) that the oil cable attaches and when you twist the throttle the disk on the oil pump turns to adjust oil pump flow.
On this disk there is usually a line also and what you do is adjust until the line on the disk aligns with the line on the block. I think in many cases they are set up to align at idle conditions.
If they are aligned now your good oil wise and your rich (fuel ) condition may be caused by carb jetting not because of too little oil.
If not aligned, correct this to get oil flow in the proper ball park.
I cannot remember off hand where to adjust the oil pump positioning, it MAY be by adjusting the cable adjuster on the oil pump cable. Double check for correct adjustment on your model.
