Post by flash2002 on Nov 25, 2018 12:09:55 GMT -5
Ok, I have a 2003 PCI tracker 50cc and I was looking at the oil pump to adjust with the throttle. On the pump there are 2 marks but on the motor there is nothing to lineup on, how do you adjust the pump.
Post by 190mech on Nov 26, 2018 5:03:22 GMT -5
Post by flash2002 on Nov 26, 2018 12:20:49 GMT -5
Thanks USMCDOC, I did check this out and, the first part about a lining up the marks is good but on mine there is no marks on the motor to line up. I guess I will have to go with the second one that is adjusted with throttle.
