Post by walleye1963 on Jan 12, 2019 16:06:26 GMT -5
hi guys. just sent for a usb charger. it has a on off switch on it . can i hook it strate to the battery with a inline fuse. going to use it for mph on phone. and having it hooked up like that will it drain the battery thanks
Post by katt on Jan 12, 2019 21:00:56 GMT -5
When i used USB thing that has LCD that shows voltage i hooked it up to some +12v wire inside harness that was not connected anywhere, but it only was powered on once key in ON position. Reason for that i did not want homeless people to charge their phones trough my scooter USB if i park somewhere overnight because if you simply hook up to the battery it will be powered all the time.
Post by 90GTVert on Jan 13, 2019 8:52:32 GMT -5
If you connect directly to the battery, any load you put on it (charging a phone for example) will drain the battery some. If the engine is running, the load from a phone charging should have hardly any affect on the electrical system.
Post by FrankenMech on Jan 13, 2019 15:06:54 GMT -5
I connected a 12V power port directly to my battery with a 10A circuit breaker. I use the port to charge my battery, run my fuel transfer pump, monitor my battery and charging voltage, and charge my phone.
Post by scooterpimp on Jan 13, 2019 15:26:29 GMT -5
That sounds like a good idea FrankenMech , my maddog has a pain in the butt location for battery access. Charge phones etc. & use to charge scoot battery .
