Post by frankwallace2003 on Jan 13, 2019 18:22:32 GMT -5
I installed a 1500 rpm spring and the yellow small 3 springs, cleaned all the parts put back togather, at that point I tried to pull the clutch open But I could not pull it open I think I might have done something wrong, OR Is it suppose to be that tight?
Post by gsx600racer on Jan 13, 2019 19:49:08 GMT -5
Pictures ?
Post by frankwallace2003 on Jan 13, 2019 20:54:59 GMT -5
Dont have pictures but i put it back togather from several videos, it looks right but i cant pull it apart by hand.
Post by gsx600racer on Jan 13, 2019 21:07:25 GMT -5
Dont have pictures but i put it back togather from several videos, it looks right but i cant pull it apart by hand. When you say "pull it apart" are you saying that you can't get the pulley to open up wider, or you can't take the assembly back apart ?
Post by frankwallace2003 on Jan 14, 2019 8:44:50 GMT -5
Dont have pictures but i put it back togather from several videos, it looks right but i cant pull it apart by hand. When you say "pull it apart" are you saying that you can't get the pulley to open up wider, or you can't take the assembly back apart ? I cant get the pulley to open wider by hand. I know it would be harder with the new 1500 rpm.
Post by tocoo on Jan 14, 2019 9:25:16 GMT -5
you can try to block the bottom with the feet and try to open the pulley with the hands. or just disassemble and assemble again ?
Post by pinkscoot on Jan 14, 2019 11:40:54 GMT -5
how far apart did you take it? It could be a stuck guides in the torque converter. Take it apart again and remove the contra spring and be sure that the pull halves will move apart.
Post by frankwallace2003 on Jan 14, 2019 18:59:47 GMT -5
how far apart did you take it? It could be a stuck guides in the torque converter. Take it apart again and remove the contra spring and be sure that the pull halves will move apart. Took it back apart for the 4th time put greese on the pins and now it moves. Thanks for the help.
Post by pinkscoot on Jan 15, 2019 11:16:23 GMT -5
Thanks for letting us know the solution.
