Post by joeesquire on Jan 17, 2019 11:22:38 GMT -5
Any opinions or suggestions for resonably priced crankshafts for my dead 90cc, which I believe is a Vento. Parts for scooters has a stocker and a TWH stuffer, both for $99. The Canadians, Distribution, have a BWS/Zuma 100 stocker, a Naraku, waaaay cheap. I just don't know if it fits. My crank measured out at 42-something mm stroke. It is now a little more than that, probably 44, since I trashed it. Hah!
I should't ask, but are any higher speed cranks around, that won't break the bank? It naturally has a 12mm pin. Also, can't find a Hoca 54mm cylinder kit any more. Any opinions on the SSP-G cylinder kits? My Hoca had 2 tiny auxiliary exhaust ports in it, since clogged.
That's my situation on my grocery gettin' rat rod. I have a a stock 90cc 50mm bore motor in it now.
thanks
Post by dexameth on Jan 17, 2019 12:04:39 GMT -5
The SSP-G 54mm Kit is just a re-branded version of the Hoca kit. Same foundary/factory, just a simple name change for certain reasons. I am told Hoca owner retired, handed down company but said "Can't use my Hoca name anymore, but you can use all specs and qualities" so the name SSP-G was born.
Post by 190mech on Jan 17, 2019 13:14:06 GMT -5
BWS 100 stuff doesnt fit,,There are some China ones on ebay,but the PFS crank will be better quality..
Post by fugaziiv on Jan 17, 2019 13:24:29 GMT -5
I should't ask, but are any higher speed cranks around, that won't break the bank? It naturally has a 12mm pin. Also, can't find a Hoca 54mm cylinder kit any more. Any opinions on the SSP-G cylinder kits? My Hoca had 2 tiny auxiliary exhaust ports in it, since clogged. That's my situation on my grocery gettin' rat rod. I have a a stock 90cc 50mm bore motor in it now. thanks
I thought for sure those 90cc TWH stuffers were long gone... Now I've gotta go look. I mean, I think I may have an open box one laying around... Matt
Post by 90GTVert on Jan 17, 2019 13:48:27 GMT -5
KaseaParts.com carries some 90cc stuff. G-ForcePowersports.com has a bunch of stuff from stock to high end.
Post by joeesquire on Jan 18, 2019 16:26:52 GMT -5
Well, sure enough, Matt was correct. The TWH stuffer is gone, and the link now connects to a stock 90 crank. Sigh.
So, guess that I'll just get a stocker for now. The 2Fast unit seemed pretty hot, but required Malossi gear to go with, and that stuff is pretty dear.
Yah, I'll probably also get the trailer hitch as well, and weld on a pick-up truck body, or a sidecar for groceries and the cat. Cat's a bit skittish about 2 smokes; she prefers the old beemers, but I still can't get her to wear the goggles, much less ear protection. Hah! She's old, like me.
Thank you for your input guys; guess that I am really part of a dying breed, as well as all my hobbies. I might as well go shop at the hardware store; I hear that they have 30 ton presses on sale. Then, the likker store. Cheers!
Post by fugaziiv on Jan 18, 2019 18:20:45 GMT -5
Well, sure enough, Matt was correct. The TWH stuffer is gone, and the link now connects to a stock 90 crank. Sigh. So, guess that I'll just get a stocker for now. The 2Fast unit seemed pretty hot, but required Malossi gear to go with, and that stuff is pretty dear. Yah, I'll probably also get the trailer hitch as well, and weld on a pick-up truck body, or a sidecar for groceries and the cat. Cat's a bit skittish about 2 smokes; she prefers the old beemers, but I still can't get her to wear the goggles, much less ear protection. Hah! She's old, like me. Thank you for your input guys; guess that I am really part of a dying breed, as well as all my hobbies. I might as well go shop at the hardware store; I hear that they have 30 ton presses on sale. Then, the likker store. Cheers! If you're interested in an open box stuffer, I'm sure I've got one kicking around. Let me know, and if it's not being held onto for any reason I'll let it go for cheap. ... I know I saw it around here somewhere... Matt
