Post by hamodyjog on Jan 21, 2019 17:37:33 GMT -5
I have a Yamaha jog 50cc 2 stroke, recently a crankshaft bearing weng bad and it seized, so now i have to remove the motor from the scooter so i can fix it, any tips and tricks on how to do that? And if I'm removing the engine and splitting it in half should i change anything for preventive maintenance? Like another bearing or something, also can i do this job with basic hand tools? No power tools, also i only have wrenches and i don't have a ratchet, can i still do it?
Post by gsx600racer on Jan 21, 2019 17:53:29 GMT -5
Post by aeroxbud on Jan 24, 2019 11:30:26 GMT -5
You will at least need a puller to get the flywheel off. These are quite cheap. Brent has a couple of different ways to install a crank shaft on his YouTube channel.
This shows the tool to remove the flywheel
