Post by katt on Jan 25, 2019 14:04:46 GMT -5
Sometimes when i stop engine it makes short but loud metallic grinding or kicking sound other times i also hear some kicking sound when i stop engine what could be doing it?
Post by gsx600racer on Jan 25, 2019 14:32:20 GMT -5
That's normal, its the starter clutch making the noise.
Post by katt on Jan 25, 2019 16:21:31 GMT -5
Here's another concern
1. Grinding noise on shutoff when i was adjusting idle i turned idle screw too tight and engine slowly died like RPM go below 500 and then stopped and i heard some grinding noise.
2. other time my idle was adjusted too low and when i started cold rpm was bit low so slightly revved the engine for a quick second followed by dropping of the center stand and backing up and i also heard some grinding noise. Could this be because my rear rear wheel was in the air and started turning and because of high rpm then i dropped it down and it suddenly locked while clutch was still engaged?
Post by 190mech on Jan 27, 2019 19:38:43 GMT -5
As gsx600racer said,the starter clutch is a one way sprag,if you reverse rotation(even momentarily),the sprag will engage the starter gear train...thus the grinding sound,,Got it?
Post by gsx600racer on Jan 27, 2019 21:11:09 GMT -5
The starter clutch could be dirty. But be warned, there are springs and rollers that can fall out when you remove it and clean it.. Remember to talk softly, it can hear every word you say. Who knows who is listening.
Post by katt on Jan 28, 2019 8:03:57 GMT -5
The starter clutch could be dirty. But be warned, there are springs and rollers that can fall out when you remove it and clean it.. Remember to talk softly, it can hear every word you say. Who knows who is listening. i cleaned it when i rebuild the engine.
