Post by katt on Jan 26, 2019 15:13:41 GMT -5
Got vibrations on idle 2000rpm vibrates 2500 okay any ideas?
Manual calls for about 1800rpm.
Post by gsx600racer on Jan 26, 2019 17:09:40 GMT -5
The gps tracker in the flywheel is throwing things off. LOL
Vibration where ? From the engine or when you rev it up and the tire spins too ?
These engines are not balanced and blueprinted.(from the factory)
Post by lilpinny on Jan 27, 2019 0:04:38 GMT -5
I'd think the tracker back to vlad might mess it up.
Post by ryan_ott on Jan 27, 2019 9:30:28 GMT -5
Makes you think back to those special OEM crank bearings.
Post by katt on Jan 27, 2019 10:17:03 GMT -5
The gps tracker in the flywheel is throwing things off. LOL Vibration where ? From the engine or when you rev it up and the tire spins too ? These engines are not balanced and blueprinted.(from the factory) Vibration from engine i guess.
2000rpm vibrates mirrors turn signals in front and back when rpm 2400 its okay.
Balancing crankshaft would help with that?
my idle is bit wired when i fire up cold engine it takes like 5 seconds for it to reach from 1200 rpm to 1800rpm.
not sure why choke does not add up RPM, last time i adjusted idle with choke closed, so with open choke it should start at about 2400RPM. Instead its hardly reach 1800 RPM.
I assume its old dirty air filter ordered replacement waiting now.
Post by gsx600racer on Jan 27, 2019 21:58:16 GMT -5
Unless your turning 10k rpm or higher for long extended periods, there is no point for balancing other than to satisfy your OCD.
Post by katt on Jan 28, 2019 8:21:07 GMT -5
Unless your turning 10k rpm or higher for long extended periods, there is no point for balancing other than to satisfy your OCD. I was under impression you mentioned this as reason for vibrations on idle speed,
what else i can balance in the engine to reduce idle vibration?
Post by gsx600racer on Jan 28, 2019 9:25:52 GMT -5
You can have it balanced by a engine machine shop, but what are you going to gain ? Sleep ?
Post by ryan_ott on Jan 28, 2019 18:20:22 GMT -5
Vibration to an extent should be expected from a non counter shaft, single cylinder engine. If it vibrates and will shake your fillings out you’ve got an issue, bent - twisted crank, if it’s just enough to remind you that it’s running - move on.
Post by gsx600racer on Jan 28, 2019 18:55:55 GMT -5
Vibration to an extent should be expected from a non counter shaft, single cylinder engine. If it vibrates and will shake your fillings out you’ve got an issue, bent - twisted crank, if it’s just enough to remind you that it’s running - move on. This is what I would consider a vibration issue. He should of built this around a van.
Post by katt on Jan 29, 2019 20:15:20 GMT -5
I put idle at 2400 RPM and seems much better now.
Post by SMALL CC TEK on Jan 30, 2019 0:11:39 GMT -5
If the manual calls for 1800 why are you at 2000 rpm ? Maybe it's set at 1800 so you can pull right past that 2000 RPM vibration and not notice it ?
Post by gsx600racer on Jan 30, 2019 0:15:58 GMT -5
Got vibrations on idle 2000rpm vibrates 2500 okay any ideas? Manual calls for about 1800rpm. If the manual calls for 1800 why are you at 2000 rpm ? Maybe it's set at 1800 so you can pull right past that 2000 RPM vibration and not notice it ? 2000 or 2400 is faster than 1800. That's cooler than it being correct.
Post by katt on Jan 30, 2019 8:49:56 GMT -5
If the manual calls for 1800 why are you at 2000 rpm ? Maybe it's set at 1800 so you can pull right past that 2000 RPM vibration and not notice it ? No vibration is anywhere 1500-1800, slower the worse, feels like engine is choking and about to cut off, headlight dim and flickers.
I'll make a video today.
