Post by frankwallace2003 on Jan 29, 2019 13:26:30 GMT -5
50cc idles fine hesitates for a second then pump throttle to get full rpm? Has to be in the idle jet MAY BE?
50cc idle
Jan 29, 2019 15:50:26 GMT -5
via mobile
Post by KSR Moto on Jan 29, 2019 15:50:26 GMT -5
50cc idles fine hesitates for a second then pump throttle to get full rpm? Has to be in the idle jet MAY BE? I belive that your carb diaphragm is culprit for this...
50cc idle
Jan 29, 2019 15:52:15 GMT -5
via mobile
Post by KSR Moto on Jan 29, 2019 15:52:15 GMT -5
Pilot jet does not influence anything above 25% throttle
Post by frankwallace2003 on Jan 29, 2019 20:20:02 GMT -5
50cc idles fine hesitates for a second then pump throttle to get full rpm? Has to be in the idle jet MAY BE? I belive that your carb diaphragm is culprit for this... You were right thanks, now its around freezing here what can i do about cold starts, What about smaller idle jet, it has a 34mm in it now.
50cc idle
Jan 30, 2019 6:21:53 GMT -5
via mobile
Post by KSR Moto on Jan 30, 2019 6:21:53 GMT -5
I belive that your carb diaphragm is culprit for this... You were right thanks, now its around freezing here what can i do about cold starts, What about smaller idle jet, it has a 34mm in it now. If your scoot is stock you dont have to mess around your carb, just keep it clean
