Post by frankwallace2003 on Jan 30, 2019 12:30:33 GMT -5
Any one know were the wire goes for the tachometer on a vip 50cc scooter? Tac not working.
Post by GrumpyUnk on Jan 30, 2019 13:39:09 GMT -5
The tachometer signal should come from the CDI or from the wire feeding the signal to the coil. The signal from the flywheel that triggers the CDI is likely not strong enough to work the coil and the CDI both at the same time, so most are connected to the 'power on/power off' coil terminal. tom
