Post by smallenginevelocity on Feb 4, 2019 16:27:01 GMT -5
Anyone have a good recommendation for a temp guys for my Zuma 50?
Post by Lucass2T on Feb 4, 2019 17:12:57 GMT -5
Runleader, backlit and runs from the battery (very quick refresh rate). You'll need a sensor too. Or you can go with a TrailTech TTO but they're not backlit and run from an internal battery that can't be replaced.
Post by ryan_ott on Feb 4, 2019 17:13:25 GMT -5
The go to is the trail tech TTO. The bad: non replaceable battery, but they are ment to last for years, not backlit and you will need the extension lead for it. So you’ll be in about $50 +/- There are cheaper alternatives on eBay and Amazon that are backlit but they devour batteries if you use the back light often. 49ccscoot.proboards.com/thread/14941/trail-tech-alternatives-updated-review
Post by gsx600racer on Feb 4, 2019 17:13:58 GMT -5
Post by smallenginevelocity on Feb 4, 2019 18:29:57 GMT -5
Post by gsx600racer on Feb 4, 2019 18:48:13 GMT -5
I have one of these on the wife's Honda Elite. Personally if I had to do this again, I'd go with 2 seperate gauges. You have to switch between tach and temp by pushing the button. This means taking your eyes of the road, one hand off the grip and remembering the right button to push to toggle between the two. Now if they made a compact gauge that showed both temp and rpm's in one package. Like this but cheaper.
Post by Lucass2T on Feb 5, 2019 0:26:26 GMT -5
Totally missed this, great write up!!!
Post by harleyracer59 on Feb 5, 2019 7:46:27 GMT -5
Post by milly on Feb 8, 2019 19:13:11 GMT -5
I got one off fleabay for approx £14, not sure what it is in dollars and it has the long lead that fits my lml. Will post link tomorrow if any help to you
Post by gsx600racer on Feb 8, 2019 19:26:02 GMT -5
Totally missed this, great write up!!! Thanks
Post by gsx600racer on Feb 8, 2019 19:34:38 GMT -5
Nice to see that they are using they higher range temp sensor.
