Post by magoconnor on Feb 4, 2019 20:11:46 GMT -5
Hello. Can anybody help me find some pilot jets for this carburetor? Also what size pilot and main jet should start with on a 90cc bvh build? When using the glixal 20mm cvk Carb
Cheers Mag.
Post by GrumpyUnk on Feb 10, 2019 12:03:08 GMT -5
Are you sure you need to change what is installed from the factory? Have you checked them? I got either a 19mm or 20mm from glixal overseas(aliexpress) that was reputed to be a Keihin. I don't think it was, but it was actually sized as listed, not bored from the intake manifold size to close to the butterfly. The butterfly was full diameter. I did not swap any jetting. tom
