Post by ThomasTPFL on Feb 5, 2019 10:52:08 GMT -5
Some carb and intake setups want a bit of intake restriction to run nicely, but at wot want all the air they can get...
I'm thinking a big reed valve on the airbox with reeds that don't want to open until high flow is happening. I might have junk laying around to test this scheme if I get a chance later this week. I have this yeller tgb that's being dumb about tuning.....
They don't need to snap closed nicely like the engine valves, so a flap of plastic may do the job.... Or maybe just a little door on a spring...
Post by gsx600racer on Feb 5, 2019 18:11:02 GMT -5
Interesting concept, might be worth experimenting with. Keep us posted with your findings.
Post by repherence2 on Feb 5, 2019 21:03:43 GMT -5
This made me think of Boyesen reeds.
Post by harleyracer59 on Feb 6, 2019 6:42:39 GMT -5
I like the idea. however, if you're having tuning issues now, I could only assume opening more air flow at any throttle position while closing it at another would only open more variables to an already hard to tune situation. like I said. I like the idea, but the "valve" would need a specific amount of force to open and close. also while it might not need to be completely air tight when closed. it would need to still close a fixed amount at a certain time or there would be another changing or variating amount of restriction to add to the tuning equation. it would have to open at a set point and close at a set point or you might be opening a whole can of lean "worms" that show up and go as they please. leaving you chasing lean conditions that are there one minute and gone the next. I don't think it will make tuning any easier and might actually make it completely non tunable altogether. I'm interested to hear your findings, good and bad... I think this might be better suited for a slow poke 4 stroke, that isn't as air sensitive as a 2 stroke.
Post by jeppetheswede on Feb 6, 2019 10:19:43 GMT -5
Wery interesting Been fiddling around with variable hood scoops with different results. It is defenetly worth a try. So ceep us updated with future results. And as harleyracer says it could bee very hard on a two stroke. But what do ikmow this is unknown terrytory for me. Only been fiddling with big fourstrokes before.
Post by snaker on Feb 6, 2019 10:49:34 GMT -5
Dan Martin over at Dans Garage Talk forum was messing around with Air Fuel Ratio sensors and whatnot with good results. Unfortunately that site seems to be closed. I think something like that would be useful for your project. You could open and cover various spots, try different things and be able to see definitive results.
Post by repherence2 on Feb 6, 2019 10:51:53 GMT -5
Thomas, I think I resolved such an issue by installing a splitter plate on my carb mouth. The idea was copied from a shop that installs a carb modification, seen it on the net. Basically the plate splits the carb mouth 50/50, like an equator. So below 1/2 throttle, all the air pulls in from the bottom half. As you go past 1/2 throttle the slide comes up above the splitter plate and air is drawn in from above and below the splitter. I think it made it easier for me to smooth out the tuning of my OKO 28. Just a thought.
Post by harleyracer59 on Feb 6, 2019 10:56:38 GMT -5
Thomas, I think I resolved such an issue by installing a splitter plate on my carb mouth. The idea was copied from a shop that installs a carb modification, seen it on the net. Basically the plate splits the carb mouth 50/50, like an equator. So below 1/2 throttle, all the air pulls in from the bottom half. As you go past 1/2 throttle the slide comes up above the splitter plate and air is drawn in from above and below the splitter. I think it made it easier for me to smooth out the tuning of my OKO 28. Just a thought. got any pics of this splitter?
Post by ThomasTPFL on Feb 6, 2019 11:30:14 GMT -5
This was a brain fart I had at work yesterday, lol. The more I dwell on it the more I think it'd just be a complicated way to get around a bad carb tune. I can't think of anything that could be accomplished with my airbox valve idea that wouldn't be more appropriately addressed with jetting or change of metering needles.
That said, If I can't sort this engine out better I'll be sending a scosh off the tip of the needle as I don't have a collection of such things and it's a $15 Chinese clone carb anyway. I just haven't swapped it for the small dellorto I have laying around because I don't want to fool wih a manual choke on this bike.
Post by repherence2 on Feb 6, 2019 20:33:39 GMT -5
Thomas, I think I resolved such an issue by installing a splitter plate on my carb mouth. The idea was copied from a shop that installs a carb modification, seen it on the net. Basically the plate splits the carb mouth 50/50, like an equator. So below 1/2 throttle, all the air pulls in from the bottom half. As you go past 1/2 throttle the slide comes up above the splitter plate and air is drawn in from above and below the splitter. I think it made it easier for me to smooth out the tuning of my OKO 28. Just a thought. got any pics of this splitter? Google: Rich's Taylor'd Porting Service. www.richstaylordporting.comHe refers to it as a "venturi divider". He has a small write up in the Venturi Divider Modification subsection.
