Post by KSR Moto on Feb 6, 2019 14:08:15 GMT -5
I have tuned my scoot last summer and ended up with 82 main jet with 47mm BBK, the temperature was around 30°C during the carb jetting, now it is around freezing point 0°C and I noticed that the scoot is running a bit slower, to what approx jet size should I go now?
Post by jackrides on Feb 6, 2019 14:09:59 GMT -5
next size larger
Post by 90GTVert on Feb 6, 2019 16:42:36 GMT -5
I'd do some tuning passes. In lieu of those, I'd stick a 90 in there and see if it ran OK. If not, down to 85-88.
Post by FrankenMech on Feb 7, 2019 9:35:46 GMT -5
Post by magoconnor on Feb 7, 2019 10:30:23 GMT -5
Post by FrankenMech on Feb 8, 2019 5:40:38 GMT -5
It is just a needle valve with a tube stuck into the air stream where air passing over the end will draw out fuel. It has a 1/4-28 thread as shown in the pictures. You drill and tap the air-horn or drill a hole in the airbox to carb connector tube. Instructions are included.
Post by scootnewb on Feb 11, 2019 18:22:40 GMT -5
