Post by 2stroked on Mar 26, 2019 19:55:33 GMT -5
SMH. Of course I was thinking about having a uni flow on it or something. Anything that is not the stock airbox attached to the mouth of the carb will flow more air. Uni/pod/sock/ whatever, it will flow better and be less restricted than the air box. Anytime you add more air going in, you need to add to add more fuel. If you do not it will run lean, and can certainly grenade your engine. Pistons are hot little sumbitches and the fuel mist acts as coolant as well as fuel. These pistons will melt a hole in the crown if you're not jetted properly.
Post by scootnewb on Mar 27, 2019 15:53:32 GMT -5
I get it. I should clarify what I meant about the Uniflow. I was thinking going from Uniflow to the Doppler. Not from air box to Doppler. Man, that thing is expensive.
dotdash
Post by dotdash on Mar 27, 2019 16:35:49 GMT -5
I can't find anything like what I linked in stock, anywhere. So stock air box for me, for now.
Post by scootnewb on Apr 7, 2019 16:02:13 GMT -5
Well today it happened. There's a cool walk or actually 'ride of shame' story that goes along with it, but feeling too burnt right now.
Post by aeroxbud on Apr 7, 2019 19:41:30 GMT -5
On dear 😢
Post by scootnewb on Apr 8, 2019 20:23:44 GMT -5
dotdash
Post by dotdash on Apr 10, 2019 12:09:39 GMT -5
Ah, link appears dead now. I appreciate the look out though. I'm still shopping around but think I'll probably start with a simple Uni and see what happens. Gotta save $$ for other stuff first though.
Post by scootnewb on Apr 10, 2019 15:11:25 GMT -5
