Post by dreck81343 on Feb 20, 2019 19:43:24 GMT -5
What's the best weights or roller size for a ruckus clone and would you run all same weights or would you mix and match
Post by fuzzyruttin on Feb 21, 2019 4:56:55 GMT -5
Lots of good info on the FAQ
Post by aeroxbud on Feb 21, 2019 5:53:10 GMT -5
Brent guide is worth a look. ^^^ There is no one size fits all for roller weight. So many things like a worn belt, contra spring stiffness, and even different brand variator can affect it. I would first make sure your CVT is in good shape. Then you will at least have a good starting point.
