Post by BunBun on Feb 24, 2019 13:35:07 GMT -5
I just got done installing my 100cc bbk and now she wont start, its making spark, has compression but wont turn over. Any ideas?
Post by Happypancake! on Feb 24, 2019 13:39:31 GMT -5
Check the timing
Post by BunBun on Feb 24, 2019 13:43:47 GMT -5
Post by BunBun on Feb 24, 2019 13:49:04 GMT -5
Is it possible that its not getting enough fuel now?
Post by BunBun on Feb 24, 2019 16:16:35 GMT -5
Okay timing was off
Post by BunBun on Feb 24, 2019 16:49:31 GMT -5
She still wont start though
Post by BunBun on Feb 25, 2019 9:40:15 GMT -5
Update: she is timed correctly, she starts with starting fluid but wont run at idle. If i wot she will keep running.
Post by pinkscoot on Mar 2, 2019 14:49:25 GMT -5
The idle circuit may be off. Have you adjusted the A/F mixture at idle? Here is a link to a thread that will help 49ccscoot.proboards.com/thread/429. Are you using the stock air box and stock carb?
Post by GrumpyUnk on Mar 5, 2019 15:30:46 GMT -5
Mebbe you jostled crud in the bottom of the carburetor and it got sucked into the main/idle jets? If the float itself got jammed during disassembly or re-assembly, it could be limiting fuel flow into the float bowl. Running on starting fluid indicates a lack of normal fuel flow, either from the tank, through the petcock, through the filter, through the float valve, or through the idle/main jet. A doubling of the volume being drawn at idle(50>100) would likely fiddle with the fuel flow through the idle circuit. I think I would try turning the idle mixture adjust screw out a bit, perhaps 1/2 turn. Doing a little adjustment on the hard stop(throttle stop) screw, perhaps 1/2 CW turn for startup, would increase the flow. tom
