Post by Critter from the Rock on Feb 24, 2019 21:19:49 GMT -5
My problem is ok until i get up to 25 miles per hour or less then it bogs out sounds like you hit the kill switch. I let off, it stays running untill I get up the RPMs again. I have bought a new carburetor, drained the gas tank, new gas, filter, line, it still does the same and it's running lean real bad and don't know why got any suggestions?
Post by FrankenMech on Feb 27, 2019 19:39:17 GMT -5
Stock air filter box?
Post by GrumpyUnk on Mar 1, 2019 13:07:15 GMT -5
Two things come to mind. Weak vacuum operated petcock which closes when you get moving, limiting fuel flow to the float bowl... OR goop in the gas tank collected at the outlet(there's likely a screen built into the outlet) and limits flow, leading to lowered level in the float bowl as fuel is used up, but refills slowly over time. tom
