Post by magoconnor on Mar 4, 2019 15:51:33 GMT -5
Hello.
I have recently acquired a polini hi-speed variator for a peugeot ludix.
Its a little bigger than my malossi multivar, but it fits without any snags.
Is the ramps angled differently being that is for a two stroke ( peugeot ludix) Or am I good to go, installing on my 139qmb?
Cheers Mag.
Post by oldgeek on Mar 4, 2019 16:47:13 GMT -5
You should be good. The polini Hi Speed for ruckus (4T) and Kymco (2T) are the same.
Post by 'O'Verse on Mar 4, 2019 16:53:13 GMT -5
I think a variator is a variator. As long as your spline count and diameter size are correct. And your variator boss length is relatively close. Bigger is better as long as it fits in the cover or doesn’t cause the belt to hit the case. Different brands of variators usually differ in angle anyway. I say run it. Only problem I could think of would be roller weight size might be different. But you can always just pick up some more rollers.
Post by gsx600racer on Mar 4, 2019 17:15:30 GMT -5
Iv ran 4 stroke variators on 2 strokes without issues.
Post by snaker on Mar 4, 2019 19:41:58 GMT -5
These variator's are rpm sensing. Don't matter if its 2 or 4 stroke as long as it fits.
Post by magoconnor on Mar 5, 2019 0:17:00 GMT -5
Good to hear The roller weights appears to be the same size to, So I will just go ahead and pop it in. Thanks for your help.
