Post by darius823 on Mar 20, 2019 9:24:37 GMT -5
Can i put 100cc kit on my 50cc gy6 scooter
Post by fugaziiv on Mar 20, 2019 10:06:12 GMT -5
Can i put 100cc kit on my 50cc gy6 scooter No, but you can put any number of kits and parts that can get you to around 95cc on your engine. This requires a stroker crank however. The largest kit that you can install is the Naraku 52.4mm kit for an honest displacement of 89.3cc. www.partsforscooters.com/137-4-Naraku-Cylinder-Kit100cc kits don't exist for your engine, it's dishonest marketing. Matt
Post by darius823 on Mar 20, 2019 10:10:59 GMT -5
Can i put 100cc kit on my 50cc gy6 scooter No, but you can put any number of kits and parts that can get you to around 95cc on your engine. This requires a stroker crank however. The largest kit that you can install is the Naraku 52.4mm kit for an honest displacement of 89.3cc. www.partsforscooters.com/137-4-Naraku-Cylinder-Kit100cc kits don't exist for your engine, it's dishonest marketing. Matt I found one with 50mm diameter wouldn't demage my engine
Post by fugaziiv on Mar 20, 2019 10:15:58 GMT -5
No, but you can put any number of kits and parts that can get you to around 95cc on your engine. This requires a stroker crank however. The largest kit that you can install is the Naraku 52.4mm kit for an honest displacement of 89.3cc. www.partsforscooters.com/137-4-Naraku-Cylinder-Kit100cc kits don't exist for your engine, it's dishonest marketing. Matt I found one with 50mm diameter wouldn't demage my engine 50mm kit would be 81.3cc, and is normally relatively safe to install if done correctly. Matt
Post by darius823 on Mar 20, 2019 10:17:14 GMT -5
I found one with 50mm diameter wouldn't demage my engine 50mm kit would be 81.3cc, and is normally relatively safe to install if done correctly. Matt Thank you very much i didn't know should i buy it but now i will
Post by darius823 on Mar 20, 2019 11:07:09 GMT -5
I found one with 50mm diameter wouldn't demage my engine 50mm kit would be 81.3cc, and is normally relatively safe to install if done correctly. Matt I want to abuot fuel consumption how much more fuel will it need
Post by GrumpyUnk on Mar 20, 2019 12:14:59 GMT -5
Fuel consumption would be higher, especially if you used the extra power available. Likely you would get in the 75-80% ballpark of what you currently get with a 49cc(39mm) piston/bore. You are increasing ~60% in displacement, but the engine should be running at less than 100% of the time a lot more often, so the carburetion would generally be better at less than wide-open use. tom
