Post by jloi on Mar 20, 2019 20:09:32 GMT -5
I could use some help getting the lower cam chain guide back in place. I didn't pay enough attention when I took it out and now I don't remember which way it goes in.no pics etc . . big mistake. I've watched a couple of vids and tried to put it in the same way I saw them come out but it doesn't seem to want to go in easy . Not sure how far it should go in and how far it should stick out . The way I have it laying in the pics is the way I saw it come out in the vids. really could use some input / confirmation . does it just lay in the bottom of the case . I thought maybe the 2 little bumps sticking off the side might go somewhere but ? can't tell
[/url] [/div]
I can take more pics if need be .
Post by snaker on Mar 21, 2019 9:17:06 GMT -5
Go to Americanlandmaster.com and click on: Manuals Fun carts Model 6150 150cc Service manual Page 28(book)or 30(pdf)
Don't know how close of a match this is but it looks similar to yours. There should be a obvious place for those pins to sit. You have to pull back the tensioner to install the guide on that side. Always keep tension on the chain so you aren't stuffing it down inside and pushing it off the bottom sprocket. Use a wire hook or something.
Post by lilpinny on Mar 21, 2019 12:14:43 GMT -5
The side facing the chain has the little grooves in it. Then you kinda just put it back to where those two little pokey things that are sticking out catch in there and keep it in place. It’s really easy, don’t over think it, is my advice.
Post by jloi on Mar 21, 2019 15:08:10 GMT -5
OK , thanks to both of you. I looked at page 28 and saw a fairly good blowup that confirms what you're telling me . All that remains is for me to get back to it and get it in . There is like a square hole down in the case in the bottom of the case and it seems like thats where those bumps would fit into . Back at it. Thanks again .
