Post by murf740 on Mar 23, 2019 6:01:22 GMT -5
Hello everyone, I just bought a new 21mm carb and a SSP-G preformance intake...my quick question is what are the 2 nipples on the intake for? Does something from the carb hook up to it? Thanks for any help as the stock intake doesn’t have it Lol
Post by Lucass2T on Mar 23, 2019 6:49:25 GMT -5
Vacuum ports for a fuel petcock or fuel pump. Dunno why there are two though.
Post by aeroxbud on Mar 23, 2019 7:31:05 GMT -5
Both vacuum lines. Different sizes so you have a choice of what fits your application best
Post by murf740 on Mar 23, 2019 7:31:55 GMT -5
So I could hook the fuel line to one and cap the other? I’m going to see what instructions if any come with it when it arrives on Monday. Thanks for the help
Post by benji on Mar 23, 2019 11:01:46 GMT -5
The small one is for oil line input.
I would take both of those out and put thread sealant on them by the way. I would also sand the mounting surface flat and use a good sealant.
Post by jackrides on Mar 24, 2019 13:29:50 GMT -5
Do not hook the fuel line to those!
Post by murf740 on Mar 26, 2019 11:35:17 GMT -5
So I believe I’m going to just seal them off if they’re not needed... new carb should not interfere with it. Thanks everyone for your knowledge and advice
Post by murf740 on Apr 18, 2019 9:10:57 GMT -5
::Update:: I installed my 70cc bbk,pref intake and 21mm OKO carb... the carb doesn’t have a spot for the oil line like the stock one! Where would I put that oil line? The smaller of the two nipples on the intake? I really didn’t want to do premix if I can still utilize the oil tank ect... Thanks a million Mike
Rune 75
Post by Rune 75 on Apr 18, 2019 9:32:02 GMT -5
::Update:: I installed my 70cc bbk,pref intake and 21mm OKO carb... the carb doesn’t have a spot for the oil line like the stock one! Where would I put that oil line? The smaller of the two nipples on the intake? I really didn’t want to do premix if I can still utilize the oil tank ect... Thanks a million Mike I would use the nipple that fits the oil hose. On the intake yes.
Post by murf740 on Apr 18, 2019 9:35:36 GMT -5
Thanks Rune75... that’s what I was leaning towards just wanted to make sure it’s right and not sure why nothing on the carb for it. Guess all are made different lol. Thanks again bro
Post by benji on Apr 18, 2019 10:47:34 GMT -5
The small one is for oil line input. I would take both of those out and put thread sealant on them by the way. I would also sand the mounting surface flat and use a good sealant.
Post by murf740 on Apr 18, 2019 18:43:00 GMT -5
Benji , I was going to put the hose from oil tank to small nipple on intake as I want to still use the oil pump ect... I’ve never done premix 😆 this OKO brand carb didn’t have oil imput or auto choke. Lol thanks for the help bro
Post by lilpinny on Apr 18, 2019 20:21:06 GMT -5
Does a PWK even work (well) on a 2-stroke?. Seems like it’s missing some things.
Post by repherence2 on Apr 18, 2019 20:42:04 GMT -5
I use CT intake manifolds, they look like the one in your picture. I use the smaller nipple for the oil injection. I use to use the larger nipple for vacuum to open the petcock. At one point I redrilled and tapped the large nipple hole and installed a larger barbed fitting so I could run a bigger vacuum hose. After a while I ditched the vacuum petcock for a manual shut off valve. At that point, I used my large barbed fitting to hook up a boost bottle, which I later removed.
Post by repherence2 on Apr 18, 2019 20:49:19 GMT -5
Does a PWK even work (well) on a 2-stroke?. Seems like it’s missing some things. OKOs and OKO clones can be set up to work well on a 2-stroke. It's a struggle to figure it out at first, but it can be done. Pretty much everyone on Oahu runs 28mm pwk OKOs.
