Post by nabblir on Apr 8, 2019 6:01:19 GMT -5
Hi! I work as a cnc operator and are looking to make my own throttle needle since there's no stores in Sweden that sell this particular part. ( instead of waiting 5-7 days it would take less than an hour ) The maker is a Baotian clone named ASA Moped Scooter 50QT-9. Everything's basically a stock Baotian Classic/City from around 2005-2006. I've been googling all day trying to find the dimensions/schematics for a stock throttle needle but can't find any at all. Asked several onlinestores if they know the dimensions with no luck. All I could find was the length of the needle ( different results between 36-38.5mm ), which is not enough. I'm wondering if anyone here knows where I could find one or maybe even knows the dimensions? or should I just give up and order one online? Sorry if I posted this in the wrong forum, I'm new to the site and couldn't understand where to post this! Regards, Nabblir.
Post by FrankenMech on Apr 8, 2019 9:46:43 GMT -5
You could remove the OEM part and measure it. An entire new carb would probably be a simpler solution.
Post by scooterpimp on Apr 8, 2019 13:40:49 GMT -5
I agree with Frankenmech , all the trouble tracking / fabricating a needle that may not work , a replacement carb would be a safer bet imo. Just my 2 cents worth
