Post by jashcb7 on Apr 10, 2019 14:10:02 GMT -5
I recently picked up a 150cc fashion sport sunl. It kicks normal once and then has too much compression and won't kick. Valves are set 0.127 book says 0.12. exhaust pipe removed makes no difference. Pull the valves and look at the piston? Not sure what I would gain there. Oil is at the correct level. Any ideas ? compression release?
Post by jackrides on Apr 10, 2019 14:40:45 GMT -5
Valve clearance is ok. Tirn the key off, pull the spark plug and kickit over. Does liquid come out of the plug hole? If so, carb float leak.
Post by jashcb7 on Apr 10, 2019 14:51:24 GMT -5
Valve clearance is ok. Tirn the key off, pull the spark plug and kickit over. Does liquid come out of the plug hole? If so, carb float leak. Carb and intake are off. There's no fuel to the carb yet or battery. There is spark. With the plug out it kicks easy enough to check spark.But can't kick it over more than 1 time with the plug in. Kickstarter is working I think since I can stand on it until the compression leaks out. I tried asking in my other thread if a battery would cause an issue but no answer.i just thought if i can get it sputtering on starting fluid then get a battery and fix fuel supply.
Post by jashcb7 on Apr 10, 2019 15:15:45 GMT -5
Sorry also just realized there is a 100cc plus trouble shoot if i belong there. But yea it kicks fine with the plug out so it can be the piston or rings?idk
