Post by atlantamods on Apr 13, 2019 13:15:38 GMT -5
okay so my scooter has been sitting for two months now and just went out side yesterday to start it up and i press in the start button knowing at all i jump the relay and it starts up fine with no problems this relay is new and the samething with my old relay i checked the wiring and everything seems fine what am i missing ?
Post by aeroxbud on Apr 13, 2019 13:50:06 GMT -5
Is the brake light switch working? Most won't start of the brakes not applied
Post by atlantamods on Apr 13, 2019 14:25:40 GMT -5
brake light comes on just as i press in the lever
Post by lilpinny on Apr 13, 2019 15:28:03 GMT -5
The starter button? I’m not sure if your bike will allow this to be done easily, but put a multimeter across the starter button leads and check for continuity when you press the start button.
Post by aeroxbud on Apr 13, 2019 15:52:58 GMT -5
It might be easier to check that power is going to the starter relay first. If not then try the switch like suggested.
Post by GrumpyUnk on Apr 14, 2019 9:47:44 GMT -5
Most have relay power coming to the relay when the key is turned to ON. The ground that makes the relay circuit complete, and energizes the relay to close the big contacts and energize the starter motor is supplied via the F & R brake lever switches and the starter button(last). Check for power to the relay(either side) when the key is ON. No power? Find where it breaks. Check for continuity, power/key OFF, from the relay to the brake switch, the starter switch... There isn't anything else. tom
Post by snaker on Apr 14, 2019 19:03:43 GMT -5
Most have relay power coming to the relay when the key is turned to ON. The ground that makes the relay circuit complete, and energizes the relay to close the big contacts and energize the starter motor is supplied via the F & R brake lever switches and the starter button(last). Check for power to the relay(either side) when the key is ON. No power? Find where it breaks. Check for continuity, power/key OFF, from the relay to the brake switch, the starter switch... There isn't anything else. tom Ahy Ya. (spelling?) Gotta confirm both hot and ground is present on that circuit.
Post by atlantamods on Apr 18, 2019 15:16:32 GMT -5
all is fixed and working now thanx for the help back relay i got
