Benji's C3
Apr 13, 2019 22:40:58 GMT -5
via mobile
Post by benji on Apr 13, 2019 22:40:58 GMT -5
Pancake where do I get the rear JDM vox panel for your taillight? Also you wanna sell your smoked lense? I have an extra for you !!!!!!!! Thanks
Benji's C3
Apr 13, 2019 22:52:49 GMT -5
via mobile
Post by benji on Apr 13, 2019 22:52:49 GMT -5
So, we're all agreed? It's cool to cut the muffler off on this thing?
Post by benji on Apr 14, 2019 0:02:04 GMT -5
Two interesting things I just found; no spacer behind the vario, but marks on the vario showing the belt can go higher. Also, I found a port on the header pipe that looks like it's maybe for emissions, but has been blocked with a 6 millimeter Bolt.
Post by 'O'Verse on Apr 14, 2019 1:38:20 GMT -5
Slam it with a 2T swap. It's already water cooled. So you mine as well go hyper race 👍. After you get your daily driver use out of it ofcoarse.
Post by Happypancake! on Apr 14, 2019 6:44:55 GMT -5
Two interesting things I just found; no spacer behind the vario, but marks on the vario showing the belt can go higher. Also, I found a port on the header pipe that looks like it's maybe for emissions, but has been blocked with a 6 millimeter Bolt. Good deal. Buy some 5gm DR Pulley sliders to push it out more (15x12)
Post by benji on Apr 14, 2019 7:53:02 GMT -5
What's OEM weight on the rollers? Do I want to go heavier or lighter?
Post by Happypancake! on Apr 14, 2019 8:12:50 GMT -5
6 gm OEM. I’d drop to 5
Benji's C3
Apr 14, 2019 12:45:54 GMT -5
via mobile
Post by benji on Apr 14, 2019 12:45:54 GMT -5
Just drilled some out What about the rear spring or clutch? I have a 107mm minarelli HiT clutch
Post by benji on Apr 14, 2019 13:39:59 GMT -5
Figured out that oem zuma variators fit. Don't know about the boss tho. I have an extra so I'm gonna mod it I think. Try to get 5-6 mph out of it.
Post by benji on Apr 14, 2019 16:37:41 GMT -5
New top speed The lighter rollers dropped my top speed a couple mph, but I sanded the variator face a little and got it back.
Benji's C3
Apr 14, 2019 16:41:04 GMT -5
via mobile
Post by benji on Apr 14, 2019 16:41:04 GMT -5
What's that squid on the exhaust do? Should I take it off?
Post by Happypancake! on Apr 14, 2019 18:50:52 GMT -5
Nada. Allows air into exhaust for complete burn.
Benji's C3
Apr 14, 2019 19:11:47 GMT -5
via mobile
Post by benji on Apr 14, 2019 19:11:47 GMT -5
Nada. Allows air into exhaust for complete burn. so rip it off and cut off the muffler?
Post by Happypancake! on Apr 14, 2019 19:16:04 GMT -5
Cut off muffler? You adding a diff one?
Benji's C3
Apr 14, 2019 19:32:09 GMT -5
via mobile
Post by benji on Apr 14, 2019 19:32:09 GMT -5
Cut off muffler? You adding a diff one? no 😎😁😉 Str8 pipe
