chinochung
Post by chinochung on Apr 13, 2019 20:18:19 GMT -5
Hey everybody. What's the correct RPMs for the scooter from the title. Mine used to die when I started it cold so I bump the RPMs to 1800 or maybe 2000 but the weird thing is that when I start it, the RPMs just to almost 4000. Then after warm up, the RPMs go from 2000 to 3500 back to 2000 randomly. Could it be a vacuum leak somewhere? Even on a brand new scooter?
I have been thinking on bringing the RPMs back to what it was when I first got it and just deal with it shutting off until it warms up. Another thing. I could swear that somehow my top end speed went down from 60MPH to 55MPH after I up the RPMs. Could it be possible?
TIA
Post by 90GTVert on Apr 15, 2019 15:44:47 GMT -5
1500-2000RPM is the typical range. If it's surging, I think you're on the right track if you check for intake/vacuum leaks.
Adjusting the idle speed screw should not affect top speed.
chinochung
Post by chinochung on Apr 15, 2019 21:32:52 GMT -5
1500-2000RPM is the typical range. If it's surging, I think you're on the right track if you check for intake/vacuum leaks. Adjusting the idle speed screw should not affect top speed. Thank you
