Post by mopedman1234 on Apr 14, 2019 13:25:58 GMT -5
I have a 2002 bws 50 with a 70 cc bbk and a foam filter with a yasuni z exhaust. When I ride when the engine is cold it runs perfect. After it warms up(about 1/2 km) when I get past 55kmh you can hear the engine sputtering. Anyone have any suggestions? Thanks.
Post by geoffh on Apr 15, 2019 14:53:15 GMT -5
Have you re jetted after the bbk,browse the the tech section for how to,keep us update
Post by mopedman1234 on Apr 15, 2019 15:05:37 GMT -5
I haven’t jetted, it has an 80 main. A while back the moped would idle but would rev so I took the throttle off and the e clip came off so I think it is in the wrong slot. There’s still 2 more slots on the pin to richen it so I’ll try that. Keep the updates on this thread?
Post by geoffh on Apr 15, 2019 15:14:13 GMT -5
I,m no bbk expert but you need to read up,get a rev counter and temp gauge or you risk destroying the engine and yes post in this thread,the scoot gods help those etc,.
Post by mopedman1234 on Apr 15, 2019 16:16:59 GMT -5
Post by mopedman1234 on Apr 15, 2019 16:19:17 GMT -5
This morning it was idling good and right now it died when I pulled into the driveway
Post by geoffh on Apr 16, 2019 14:54:37 GMT -5
You need to up jet the carb buy a kit like this,up the jet till it won,t run then move back down till it will This is a European make cost £15 Geoff
Post by mopedman1234 on Apr 16, 2019 16:19:21 GMT -5
Ok thanks
Post by mopedman1234 on Apr 16, 2019 16:43:00 GMT -5
I’m going to try moving the throttle clip down one to see if I can get a bit more fuel out of it. And also when the engine is warm it looses a bit of power. Does all these reasons sound like a lack of fuel issue?
Thanks
Post by geoffh on Apr 17, 2019 14:40:22 GMT -5
OK it,s on you,your plug looks to show a lean condition altering the clip just won,t be enough,you have increased the engine size but not the amount of gas,disaster looms,read the tec sect.
Post by rancevas on Apr 17, 2019 14:43:56 GMT -5
Check the fuel lines and fuel filter. if insufficient amount of fuel gets into the float bowl that might decrease the power. I'm not sure what you mean by "sputtering". Is it four-stroking or etc. Could you describe the sound more specifically?
Maybe the mixture is too rich, have you thought of that? Did it get better after you had more fuel getting into the cylinder? Have you tried running it with the choke on? If it runs better with choke on that definitely means you need a richer mixture.
I'll touch upon engine loosing power when warm later on
We'll be waiting for you to report back.
Post by mopedman1234 on Apr 17, 2019 15:14:31 GMT -5
A few weeks ago, I had the same setup and it was running fine. My next thought was just what you said, it might be clogged up somewhere in the tank or the fuel line I will check those tonight and post if it’s fixed
Thanks
Post by mopedman1234 on Apr 17, 2019 15:18:35 GMT -5
Last Wednesday the pressure line that pushes fuel out of the tank came off. The line might have some dirt in it so no pressure will be getting pushed through. The sputtering is like a struggle to rev out. When it’s held full throttle it cuts in and out like the kill switch is getting turned on and off, just like the sound it made when the pressure line came off.
mattyslimz
Post by mattyslimz on Apr 17, 2019 18:18:54 GMT -5
Running the foam filter without airbox will surely cause a lean running condition on the STOCK carb. I’m running a foam filter on my 70 but it has a 19 carb. I was worried about it running lean before running it, but after break-in and longer travel distance plug check/chops revealed otherwise. I’ve tried running a foam filter on stock carb/jetting 50cc and 70cc, I can attest that you’ll find it losing more power because over heating, cut-off at high rpm on WOT and evidence of lighter color almost chalky looking plugs. Other members suggested an up jet which is great, I’ve found a larger carb with your bbk will probably be pretty close right off the bat, especially if you like running a foam filter like myself.
Post by mopedman1234 on Apr 17, 2019 20:29:59 GMT -5
The Cylinder is only 350 F fully warm
