Post by mopedman1234 on Apr 14, 2019 22:27:57 GMT -5
Hi I have a 2002 bws 50 w/ a 70cc BBK yasuni z exhaust, foam filter. When I get to 50kmh it sputters and if you hold it long enough sometimes it clears up and hits top speed. Also it only does it when it’s warm. Anyone have any ideas?
Thanks.
Post by Happypancake! on Apr 15, 2019 7:03:45 GMT -5
If it also backfires you may be going lean. Check for air leaks if none try to upjet or move the needle clip down (if applicable )
Post by mopedman1234 on Apr 15, 2019 10:32:26 GMT -5
Ok thanks man I will move the clip so it will get more fuel right?
Post by mopedman1234 on Apr 15, 2019 10:33:33 GMT -5
The backfires aren’t too loud but sometimes it does pop a little louder than usual
Post by mopedman1234 on Apr 15, 2019 14:24:20 GMT -5
How do I check for air leaks
