Post by mike007 on Apr 16, 2019 14:26:00 GMT -5
Post by oldgeek on Apr 16, 2019 14:30:18 GMT -5
You are correct. That is a carb for a 4T.
Post by mike007 on Apr 16, 2019 14:42:25 GMT -5
ok thanks, looks like i'll be on the hunt for a 2-stroke carb for this thing. cant find much info about these scooters other then being made in taiwan an a Moto Morini TGB Suzuki style 50cc clone motor?
Post by ThomasTPFL on Apr 16, 2019 18:12:05 GMT -5
It's a TGB. It should have a Mikuni on it stock I believe. I'd say I'd send you one but the stock one I have seems to be junk after sitting in the elements for too long.
Any of the Jog style carbs you can find around should work fine with proper jetting.
Post by mike007 on Apr 16, 2019 18:43:01 GMT -5
ok thanks, i'll look around an see if i can find any jog style ones. i'd even trade this carb for one that would work if anyone happens to have one LOL
Post by oldgeek on Apr 16, 2019 19:21:58 GMT -5
ok thanks, i'll look around an see if i can find any jog style ones. i'd even trade this carb for one that would work if anyone happens to have one LOL Ya know, it would not be a bad idea to post pictures of your carb in the for sale section. It appears to be a decent quality carb for a 4T.
Post by mike007 on Apr 22, 2019 6:15:53 GMT -5
well i picked up some more junk scoots over the weekend for parts an one of em just happened to be a TGB with a stock carb still on it. i'm sure it'll need a good cleaning but i'm gonna give it a go an see what happens.
Post by mike007 on Apr 24, 2019 16:45:06 GMT -5
got the carb cleaned an it fired right up an runs like a new one!! amazing what using the correct carb for a motor will do LOL..
Post by repherence2 on Apr 24, 2019 20:14:52 GMT -5
got the carb cleaned an it fired right up an runs like a new one!! amazing what using the correct carb for a motor will do LOL.. Congratulations mike007. I'm happy for you. Ride safe!
tas50
Post by tas50 on Apr 24, 2019 20:40:16 GMT -5
Good Job Mike. I never thought there was a difference between a 2T and 4T carb. Always a Good feeling when things come to together.
Post by rancevas on Apr 26, 2019 5:54:30 GMT -5
Good Job Mike. I never thought there was a difference between a 2T and 4T carb. Always a Good feeling when things come to together. Oh yeah, there is a large difference between those two. 4 stroke carbs usually have a butterfly valve. Throttle only changes the amount of air that's getting in. Fuel, supplied to the cylinder is regulated automatically. It does it by having a needle attached to a diaphragm. When cylinder creates a vacuum to pull in the mixture (intake stroke), diaphragm moves up because of that same vacuum and allows fuel to get in. If you take a look at it while the engine is working you would see that it constantly jumps up and down real fast. That makes it great for fuel efficiency. Why? The fuel is only supplied when the cylinder needs it. Also, it works depending on the air pressure, so it makes it efficient over a bigger range of altitudes (I'm not sure about this one, correct me if I'm wrong) 2 strokes on the other hand have a valve with a needle attached to it. Throttle changes the amount of air AND fuel that gets into the cylinder manually. And the amount (ratio) is fixed. Depending on the altitude you might require different jets. Overall, 4 stroke carbs are more efficient but very complex 2 stroke carbs are more fun - faster, very easy to disassemble and work on, but fuel consumption and emissions are through the roof. Again, correct me if I'm wrong.
