Post by walleye1963 on Apr 18, 2019 14:01:04 GMT -5
Hi All I got the new tao tao Evo 50 did Bart's pdi .put a new carb on .the problem I'm having is when I take off is it's slow then it will revert hi and take off I can fell it shift into hi grear 6 gm sliders orang cdi and coil set air and fuil mix.spark plug looks rich . Please help
Post by jstich on Apr 18, 2019 23:39:01 GMT -5
For my tao tao vip 50 if its cold out itll have a delay in the throttle.When i let it warm up it goes away. But in my case I think its running too lean.
Post by 90GTVert on Apr 19, 2019 4:37:12 GMT -5
have you tried changing main jets? How about lighter rollers or stiffer clutch springs?
Post by walleye1963 on Apr 21, 2019 19:34:42 GMT -5
I haven't got in to the clutch yet.getting a impack at the end of the month.put a new carb on with a 80 main jet.starts up better everything is still stock but the carb.i can feel it shift at least 2 times.ill wait until I get the impack then look at the clutch.ill be back.
Post by walleye1963 on Apr 22, 2019 19:01:39 GMT -5
Hi guys.iv put about 160 miles on my new taotao evo50 I got a new bbk so I went out today and started to put it on. put new piston on and was about to put the jug on then I realized I messed up I didn't look or take pictures of were the spacers went.so what I'm asking is does anyone have. Pictures of were they go.i haven't bolted nothing down put I ended up with 2 extra.any help will surely be appreciated.thanks guys.
Post by jackrides on Apr 23, 2019 11:43:18 GMT -5
What do the spacers look like?
Post by walleye1963 on Apr 23, 2019 17:07:47 GMT -5
There silver.if you've seen Brent's how to bbk at 1 pont he said he for got to put the spacers in.thats were I'm at I didn't take pictures and nothing wants to fit please help.
Post by GrumpyUnk on Apr 24, 2019 10:10:02 GMT -5
OK. They are silver. That is a pathetic response. I am not going to go searching for a post that you obviously have found. You could have posted a link and saved people their time.
Only close thing that comes to mind that is close to being a spacer when doing a BBK are the flat washers under the nuts at the top of the studs, above the rocker arm assembly. Each stud gets one washer.
If you refer to the ferrules that align the cylinder to the block, and align the head to the cylinder, look into the holes bored in each. Those that require a ferrule have a larger diameter. If you have bent the studs, it will make installation of the ferrules a lot harder. It will also make installation of the head to the cylinder difficult AND make installation of the rocker arm carrier harder. tom
Post by walleye1963 on Apr 25, 2019 11:59:40 GMT -5
Sorry I asked grumpy.i thought people on here were suppose to help but your just to grumpy for me.and yes the ferruules is what I was asking about.i ended up with 2 extra and it runs great I think you need to go back sleep and get up on the right side of the bed.
Post by walleye1963 on Apr 25, 2019 16:54:58 GMT -5
Went for a long ride.useing my phone got it up to60 things a bist.and still had more.
Post by GrumpyUnk on Apr 25, 2019 20:51:49 GMT -5
Oooh. Touchy. It is common courtesy to make clear what you are asking about. If you don't agree, that's fine. tom
Post by walleye1963 on Apr 25, 2019 23:50:28 GMT -5
I'm sorry grumpy.i didn't know the name of the furruis as u call them I call them spacers.and they fit eveywere on the jug.and the head so I didn't know were what fit were so I just put them were I thought they went.and it runs like a beast.so iil run it like it is untill it blows.ànd go from there.no biggie
Post by GrumpyUnk on Apr 26, 2019 7:25:47 GMT -5
The ferrules align the pieces as they are 'stacked up', keeping things to they work. If left out, the cylinder could move LR/up/down, and get out of alignment, putting the connecting rod under strain from 'angled' force. Similarly, the timing chaing could be off-center, putting side force on the cam, etc. Same thing applies for the cylinder head and cam follower carrier. It just works a bit better when all are aligned, and may likely add to longevity. If you got at least one at every level, you will likely be fine. tom
