Post by magoconnor on Apr 26, 2019 22:58:39 GMT -5
Hello. I have these two stators, and I'm wondering which one will produce the most watts, and give me the strongest charging system. Or is the difference minimal. The 6 pole stator has significantly larger coils. Picture below: Is there some way I can measure it, with a multimeter? Tell me what you think. Cheers Mag.
Post by rancevas on Apr 27, 2019 6:08:36 GMT -5
8 pole stator will produce more power than 6 pole. Although I suggest you stick to the original amount of poles with which your scooter came with. A bigger surge of power might blow some fuses.
tas50
Post by tas50 on Apr 27, 2019 6:57:38 GMT -5
If scooters are anything like motorcycles......the number of poles is dictated by the number of magnets in the hub. I have an old suzuki with a 12 pole stator and cannot use an 18 pole stator because I have, I think, 4 magnets in the hub compared to 6 that that 18 pole stator needs to work properly. I could change the hub though but it’s more than what I want to do at this time.
