Post by robsar on Apr 30, 2019 11:03:42 GMT -5
New to the forum Doing a big bore kit installation on a qmb 139 49cc scooter. My question is this. My marks on my camshaft with piston at top dead show the two small holes in line verically but the larger hole facing the back of my engine not the front as everything says it should be. Is this normal? Scooter always ran fine in that position.
Post by robsar on Apr 30, 2019 11:41:58 GMT -5
Post by lilpinny on Apr 30, 2019 11:52:13 GMT -5
Change it and see what happens. Usually though, you have the two holes vertical with the case and the big hole perpendicular to that same line facing outward.
Rune 75
Post by Rune 75 on Apr 30, 2019 11:54:30 GMT -5
Have you actually confirmed piston is at tds or just placed flywheel on the mark ? One full rotation of the flywheel will rotate camshaft 1/2 rotation.
Post by robsar on Apr 30, 2019 11:57:49 GMT -5
Yes Was tdc. Checked piston and timing mark.
Rune 75
Post by Rune 75 on Apr 30, 2019 12:09:26 GMT -5
Turn flywheel one rotation and everything will be in place.
Post by lilpinny on Apr 30, 2019 12:39:30 GMT -5
If it ain’t broke, dont fix it it.
