Wiring
May 7, 2019 10:19:00 GMT -5
Post by flash2002 on May 7, 2019 10:19:00 GMT -5
Hi guy's, I have a 2003 CPI 50cc tracker 2 stroke and I'm trying to figure out the wiring from the start switch and kill switch to the bike. I can't seem to find the wiring diagram for this bike, the ones I find for scooters don't match the color or diagram. Does anybody have this diagram or know where to find it. I did have it running but could not turn it off with the key or kill switch. Thanks
Wiring
May 7, 2019 10:44:30 GMT -5
Post by dexameth on May 7, 2019 10:44:30 GMT -5
It's gonna be hard to find the exact wiring diagram for that model. BUT, if it's an AC fired system make sure the kill wire is connected to the CDI.
Wiring
May 7, 2019 12:33:19 GMT -5
Post by flash2002 on May 7, 2019 12:33:19 GMT -5
This is what I got. from the right controls, the blue, yellow red band and the yellow with the black band come from the kill switch. The blue with the white band and the black come from the starter button. The blue and white from the button goes to the starter relay. When you turn on the key, the blue gives power to the yellow black and yellow red depending which way the kill switch is on . I normally don't have problems with but this is weird. I did have it running at one point but could not stop it unless I unplug a wire. I just can't figure this one out. I put pictures of the wires.
