Post by ispepfun on May 9, 2019 6:18:54 GMT -5
I got a 49cc but installed a 47mm big bore,bought a 20mm carb but just can't get carb set up right
Post by wingnut on May 9, 2019 7:38:57 GMT -5
Well...as a person who has been through this, a bit more information might be helpful...
1) does it idle? 2) is the auto enrichment system functioning? 3) does it accelerate? 4) does it run at high rpm? 5) what have you tried so far? 6) does it run with old carb?
...just some thoughts...
Post by pinkscoot on May 9, 2019 9:15:00 GMT -5
What engine are we talking about?
lupo76
Post by lupo76 on May 9, 2019 9:31:55 GMT -5
I got a 49cc but installed a 47mm big bore,bought a 20mm carb but just can't get carb set up right Also, how about introducing yourself?
Post by ispepfun on May 20, 2019 0:42:20 GMT -5
Can get it to start easy idle but bogging down on excelleration, doesn't get rpms above 5500.old carb same thing.when I got it it didn't have factory air box.only thing I can see is the more I mess with air fuel components it shows signs of in proof ment. Think it's getting to much air for jet installed or just to much fuel all around
