Post by stancejontland on May 17, 2019 16:48:35 GMT -5
so i would clamp the piston back down like on a car when you change your pads? or is it different?
Post by stancejontland on May 17, 2019 19:30:22 GMT -5
So i had it empty and i had full movement of my lever not hard at all to move. So i reverse filled it with the master cap off and it seemed to work a little bit better as in pulling the lever back easier. But is still pretty tough to squeeze.
Post by aeroxbud on May 18, 2019 0:36:50 GMT -5
so i would clamp the piston back down like on a car when you change your pads? or is it different? If you undo the caliper. Take out the pads. Then as to squeeze the lever, you should see the piston come out. It should slide out easily, and smoothly. If it's twin piston on each side one might come out faster than the other. By holding one the other should slide more. Once they are out about 5mm give them a clean with an old tooth brush, and brake cleaner. You should be able to push them back in by hand pressure. Making sure they are straight. If hard to push in there is something wrong.
Post by stancejontland on May 18, 2019 1:11:33 GMT -5
Ok i have fluid in there now would that make any difference? I guess i kinda need fluid to get the piston to move.
Post by aeroxbud on May 18, 2019 6:57:51 GMT -5
Yes you need fluid to put pressure in the system
Post by stancejontland on May 18, 2019 12:52:58 GMT -5
That is what my caliper looks like
Post by stancejontland on May 18, 2019 23:40:15 GMT -5
Im using dot 3. Would that make any difference? I used the same dot 3 last time and it was fine.
Post by aeroxbud on May 19, 2019 12:44:04 GMT -5
Dot 3 will work. It's not as good as Dot 4 having a higher water content. How old is the Dot 3? When did you open it? It's always best to use a new unopened container if possible.
Post by stancejontland on May 19, 2019 17:28:02 GMT -5
I would say i opened it in the middle of winter. Its clear and clean. Always sealed. Just need some ideas what to try to get the lever pressure right.
Post by ryan_ott on May 19, 2019 18:06:05 GMT -5
Pull the piston and inspect for corrosion Clean and lube the slides Refill and bleed with fresh fluid from a new sealed container That “abs” restrictor could be full of junk. Usually if the hose is long enough you can unbolt from the “abs” remove the abs from the caliper and attach the hose directly to the caliper. If it still doesn’t work just replace the master cylinder and caliper I’m sure they could be sourced for under $50 Piston location: Slides: 1 888 751 9000
Post by stancejontland on May 19, 2019 23:47:26 GMT -5
so your sayin just bypass the abs thing. and what is the slide? the pin looking things. i guess ill pull it apart tomorrow. ill post pics.
Post by stancejontland on May 20, 2019 12:52:42 GMT -5
Ok guys i got the caliper off but i cannon get the piston out. At least by hand. I can't push it or pull it. But when i push on it fluid fluctuates in the abs thing. I dont have any brake cleaner so ill have to go get some before i get much farther.
Post by aeroxbud on May 20, 2019 14:19:55 GMT -5
You don't have to take it all the way out. You should be able to pull the lever, and it should slowly come out. You want it out enough so you can see clean metal and no road grime.
Post by stancejontland on May 20, 2019 14:49:08 GMT -5
Post by stancejontland on May 20, 2019 14:51:03 GMT -5
Wait nevermind im not going to lube the slide i read ryans comment.
