Post by 2smokeruck on May 12, 2019 20:33:31 GMT -5
So i finally mounted my motor. Stage6 intake, malossi reeds with a spacer. Carb is hitting the frame and cant even get the intake on. Any suggestions??
Post by ryan_ott on May 12, 2019 21:04:08 GMT -5
Is it the Stage6 2 piece intake? Those are longer then a upgraded stock type. Your best bet would be the 360 deg intakes or a rear facing one.
Post by tsimi on May 12, 2019 22:11:19 GMT -5
LoL I know this situation. Had similar problems with mine but my frame was a bit smaller then yours. As Ryan said try one of those 360 intakes. You are more flexible in positioning the carb with those. Malossi, Polini and Top Performance has those I think.
Post by Lucass2T on May 13, 2019 11:19:17 GMT -5
Build your own intake? Thats what i'm gonna do with my YA50 axis.
Post by 'O'Verse on May 13, 2019 11:53:47 GMT -5
Jig saw... metal blade. Half circle shape taken out the frame. About a 1/2” more in diameter around the carb for filter clearance and shock movement. There’s enough meat left on the webbing of the support. The bell of your carb is so close to the frame that getting type of filter seated will be difficult.
Post by 2smokeruck on May 13, 2019 16:01:12 GMT -5
I looked at it again and theres a small tab on the carb thats hitting the frame. Gonna try to shave it down and see of that helps.
Post by 2smokeruck on May 15, 2019 22:51:35 GMT -5
Ended up ordering a malossi 360 intake. Cut off the tab on the carb and it was still hitting. Another question. The 360 doesnt seem to have a nipple for a vacuum line. I have a 21mm pwk Stage6 carb. Where does the petcock vacuum line go?
