Post by vernw3 on May 12, 2019 22:23:14 GMT -5
I need the bolt and the spring that connects the brake line to the brakes But i have no idea what to search to find it
Post by jackrides on May 13, 2019 11:18:28 GMT -5
If you can't find the exact parts, a good hardware store has the cure. Take 2 nuts with beer and call me in the morning. Anyway, the store will have a spring that fits, a short spacer to go ahead of the nuts, and 2 nuts so you can lock them together.
Post by vernw3 on May 13, 2019 21:07:35 GMT -5
If you can't find the exact parts, a good hardware store has the cure. Take 2 nuts with beer and call me in the morning. Anyway, the store will have a spring that fits, a short spacer to go ahead of the nuts, and 2 nuts so you can lock them together. Its not even a bolt i just cant think of a name for it here a pic of what i need
Post by jackrides on May 14, 2019 13:32:59 GMT -5
Its a holedowell. Make one with a hacksaw, drill and the unthreaded part of a bolt. Exact fit isn't critical.
Post by 'O'Verse on May 14, 2019 23:06:33 GMT -5
Post by tsimi on May 15, 2019 2:46:53 GMT -5
That part is the same throughout all Jogs. My CV50 2003 has the same so does an older 3YK CY50 Jog. As already mentioned you could find a matching bolt cut it and drill a hole through it and it will do just fine. I would guess a M10 bolt should be just right for this. But check to be 100% sure.
