Post by magoconnor on May 13, 2019 15:52:37 GMT -5
Hello.
Does the choke run on ac or dc? I have seen diagrams where it gets ac directly from the stator, and others where its supplied from the battery (dc). What do you think I should do?
139qmb gliaxl 20mm carb and choke.
Post by FrankenMech on May 14, 2019 2:54:09 GMT -5
Connect the enricher to the stator.
Post by dexameth on May 14, 2019 10:56:51 GMT -5
Runs on AC. Manufacturers don't want the enricher to engage with the key so you don't turn the key, wait a while and now your enricher is already shut off. It gets power from the stator, so as soon as the engine fires up the thermoplastic will start to heat up and slowly shut off the enrichment after almost a minute, at this time your engine should be at a healthy running temperature.
Post by magoconnor on Jul 24, 2019 23:45:35 GMT -5
Ok just to make sure. I should just run it straight of the yellow wire coming from the stator? nothing in between?
