Post by seif on May 14, 2019 19:04:09 GMT -5
So i posted here before that i got a 2016 tmec vip 50cc scooter that the seller stated that it ran perfectly fine until the drive belt broke and I thought it would be an easy $10 fix , well im now $200+ in and still cant get it to start , i replaced the carburetor with a performance one , performance ignition coil and cdi box , free flow air filter , replaced the fuel lines and filter and a bunch of other parts just to find out that the compression is not enough to run the engine , I thought that there is no going back at this stage and i need to get it running, so since im tearing the engine apart I’ve considered a 48mm bbk , and already ordered one of amazon which contains everything i need except for the valve head which im gonna be reusing of the old engine, so i need help with the whole engine overhauling procedure and the break in process , and also i want to delete the emission system, can i just but i piece of metal or rubber under the pipe bolts to block the hole for the emission system?
Post by aeroxbud on May 15, 2019 3:05:49 GMT -5
Here is a guide to removing emissions pair systems
I have never played with a GY6, but i think it you run the 50cc head you will get quite high compression. Some like it. Some dont.
Post by 90GTVert on May 15, 2019 6:18:41 GMT -5
