Post by slim95x on May 15, 2019 3:37:13 GMT -5
What are the stock carb and throttle cable setting on a baotian scooter? Long story short, scooter didnt run on high rpm, took the carb off, opened it, one jet was clogged, cleaned it, put it back on, now THE GOD DAMN THING WONT START Been scratching my head for two days now, cant get why it does not run. Im getting spark, already checked it, its just something with the fuel or fuel related. Throttle cable is set up so there's no slack in it, and it starts opening the carb as soon as you turn the accelerator handle. Tried playing with the low speed and idle speed screws, but still the same, or maybe im doing something wrong. Before, the scooter started with no problem, but after cleaning the jet, it kinda wants to start, i can hear slight combustion sometimes, and a tiny bit of smoke, but thats about it. ALl i want to do is ride it Also, can go out, take some pictures and put them here if it helps.
Post by tortoise2 on May 15, 2019 4:08:48 GMT -5
can go out, take some pictures and put them here if it helps Might . . example.
Post by slim95x on May 15, 2019 4:13:38 GMT -5
THanks a lot, seems like a great start for troubleshooting. Will go and check what might be wrong
Post by slim95x on May 15, 2019 4:40:12 GMT -5
I think i found the problem My dumbass self conected the fuel line to the overflow drain on the top of the carb Reconnected it, hopefully it will start now.
Post by RedRyder on May 24, 2019 20:51:09 GMT -5
oops! Don't feel bad. My bad, when installing a new carb was attaching the fuel line to the drain port. But then, this was my first scoot and only hours old. I've learned a "bunch" from the "smarty pants" on this forum.
Post by FrankenMech on May 26, 2019 22:59:13 GMT -5
Do yourselves a favor and find a service manual for a scoot similar to yours in the manuals section and read it some to see what is in it. Then follow the diagrams and troubleshooting instructions it has. It will save you huge amounts of time and start your scoot education off right.
BTW, use an ANALOG voltmeter to do your voltage checks during troubleshooting. The digital meters do not provide consistent readings unless you are an expert and understand what you are looking at.
