Post by ispepfun on May 15, 2019 20:34:58 GMT -5
I would like to put 12 inch rims on my roketa 50 that has 10 inch.is that feasible and we're be good place to find them.would drum brakes be no prob?
Post by lilpinny on May 15, 2019 20:50:14 GMT -5
Machined machines has the wheels. You usually swap out the brakes. They can't use the old ones. Won't fit.
Post by lilpinny on May 15, 2019 20:50:35 GMT -5
Post by ispepfun on May 20, 2019 0:43:51 GMT -5
Thanks
Post by fugaziiv on May 20, 2019 8:05:20 GMT -5
Post by ispepfun on May 22, 2019 12:56:51 GMT -5
Even if on 12 inch rim u use a a tire with really small sidewalla?
Post by ispepfun on May 22, 2019 12:58:32 GMT -5
What about if a guy wanted to put a fatty tire on 10 inch rim what's needed or place to go
Post by fugaziiv on May 22, 2019 13:13:38 GMT -5
The lowest profile 12 out there is the Kenda K433 100/60-12This tire is still a bit taller than the standard shortcase 3.50-10 tire, so I don't think it's gonna work. As far as fatty conversions, we don't get into those so I don't have much advice there. Once again however, unless you really stretch out that rear tire on a wide wheel, I suspect on a shortcase engine you may run into clearance issues. I'm sure someone else can drop in with more info on this. Matt
Post by lilpinny on May 22, 2019 16:27:24 GMT -5
I’d check to see if they even make a 10’’ fatty wheel. And if they did, I’d ask if it’ll work on a short case. the width of the wheel does lower the profile, but you never know.
Post by ispepfun on May 23, 2019 6:43:09 GMT -5
Thanks alot for the info,still kind of new at these scooters.any advice is much appreciated
