Post by benjiescoots on May 15, 2019 23:38:59 GMT -5
Hey there, I own a 2001 Hyosung Sense 2t. I have gotten it running, but cant seem to fix this bogging issue. After about 1/4 throttle it starts to bog, anything more then that cuts out. Fuel system is clean (tank, hoses and carb) Air box is modded, works better with more air Vaccuum seems fine, added a gasket from intake to carb, made sure intake was screwed down tight etc. Always fuel in the line. Here is a short Video: www.youtube.com/watch?v=xg6XNTIggtkHere are some pics:
Post by repherence2 on May 16, 2019 0:21:54 GMT -5
"air box is modded. works better with more air"...Really?
that's the whole reason you got that Bog after 1/4 throttle.
...works better with more air... ...with proper jetting for sure.
Post by benjiescoots on May 16, 2019 2:28:13 GMT -5
Simply an observation. Wasn't the one who drilled the holes, also tried covering them with no results. Thanks for being helpful! -_-
Post by aeroxbud on May 16, 2019 3:51:58 GMT -5
Has this scooter run ok before? Or did you get it with this problem?
Post by pinkscoot on May 16, 2019 10:56:45 GMT -5
I will assume that the picture of the cooling shroud off is for us to see. If not don't run it long without the piece missing from the stator side or you will overheat and seize your engine.
Post by benjiescoots on May 16, 2019 11:02:42 GMT -5
Has been like this since I got the bike running. Wouldn't start when I got it. I'm thinking of replacing the carb entirely, for the money it's well worth not having a question mark carb with unknown jets.
My issue there is A, almost every dellorto or equivalent carb seems to not have the proper connection to the intake. B, if I'm going a better carb, cable choke? If so I'm new to how that would operate.
Post by repherence2 on May 16, 2019 20:06:08 GMT -5
Simply an observation. Wasn't the one who drilled the holes, also tried covering them with no results. Thanks for being helpful! -_- no problem.
Post by pinkscoot on May 16, 2019 20:49:00 GMT -5
I saw somewhere where a guy cut the flange off and used an intake boot. He dremeled a groove in the intake to hold the boot better. While he was there he opened it up to 19mm.
