Post by darius823 on May 21, 2019 15:29:35 GMT -5
Today i was driving my scooter i stopped and turned off the engine after 10-20min it didn't start then i noticed that from air filter box was leaking petrol. Thanks
Post by jackrides on May 21, 2019 15:39:01 GMT -5
First, clamp off the fuel and vacuum lines to the gas tank. Probably junk stuck in the float valve in the carb. Worked on scoots before?
Post by darius823 on May 21, 2019 15:56:44 GMT -5
First, clamp off the fuel and vacuum lines to the gas tank. Probably junk stuck in the float valve in the carb. Worked on scoots before? Yes on mine own
Post by jackrides on May 22, 2019 12:35:37 GMT -5
Remove the carb leaving the cable on it. Remove the float bowl screws - if no place for screwdriver, welcome to scoot world. There have been a few posts on how to remove them. When finally removed, gently smack the float bowl with the handle of the screwdriver to break loose the gasket. See if there is junk in the bottom and set aside to hold the: float pin, float, and the float valve. Let a shot of gas flow out to flush the line. Reassemble.
Post by RedRyder on May 23, 2019 21:56:24 GMT -5
Check your float level. It's possible the needle (float bowl) is not seating. On some carbs there is an overflow tube that allows excess fuel, if flooding, to exit. The excess fuel is being back drafted,
Post by GrumpyUnk on May 30, 2019 14:23:38 GMT -5
The one scoot that dumped fuel out of the air cleaner housing had a stuck float valve. The overflow elbow is higher up than the bottom of the venturi, and fuel level in the bowl rose and must have come out around the main jet, dribbled towards the intake tube and air cleaner, and finally dropped onto the ground. I just had to clean things up and it worked again and quit peeing gasoline. tom
