Post by freddy on May 23, 2019 19:48:55 GMT -5
After changing my gear , something in my cvt started making noise. After riding a little and reaching 75kmh i slowed down and it mad a scisling metalic noise .
It only happens when I slow down (releasing the throtlle) and when I’m over 70 km/h
Post by repherence2 on May 23, 2019 20:06:03 GMT -5
After changing my gear , something in my cvt started making noise. After riding a little and reaching 75kmh i slowed down and it mad a scisling metalic noise . It only happens when I slow down (releasing the throtlle) and when I’m over 70 km/h did you put oil in the gear box?
Post by freddy on May 23, 2019 20:47:47 GMT -5
Yes i put oil change the bearing everything changed the gasket maybe it could be link to the problem before the gear when my clutch was overheating and getting stuck on the belle . The one who got stuck got change by my delta and I rode it a little bit but not a lot so maybe my spring are fucked?
Post by aeroxbud on May 24, 2019 2:32:45 GMT -5
Did you change the gear for straight cut gears? They are a lot louder than the standard gears.
Post by freddy on May 25, 2019 8:55:31 GMT -5
Did you change the gear for straight cut gears? They are a lot louder than the standard gears. Nop I put 15/50 and brought to a mechanic thanks for your help
